Anti rust High temp paint?
Vfr400/tbird
Bike owned: VFR400 NC21 Thunderbird 900
Post by Vfr400/tbird » Sat Feb 04, 2012 4:36 pm
Hi,
Im going to paint my collector, because at this time its going to be impossible to aford to replace it and its getting a bit red with the salt and harshness of winter!
Can anyone recomend a good rust proof high temprature paint thats suitable for the collector?
ludacris
Bike owned: NC35
Re: Anti rust High temp paint?
Post by ludacris » Sat Feb 04, 2012 6:34 pm
i think you need to use anti-rust primer and then the high temp paint...
not saying it doesn't exist but i've never come across high temp paint that had anti-rust properties also
Vfr400/tbird
Post by Vfr400/tbird » Sat Feb 04, 2012 6:46 pm
I was thinking the same thing but im not sure how heat proof the primer is and if that breaks up and flakes or bubbles then the problem remains the same.
It must exist in theory as theres too many applications in which it could be used for, im going to ask somewhere that specializes in marine equipment as it might point me in the right direction, once i get a product name i can find a cheaper one!
Ill post the results!
duncan
Post by duncan » Sat Feb 04, 2012 6:56 pm
Try good old Hammerite
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack » Sat Feb 04, 2012 6:59 pm
Use vht paint?
Post by Neosophist » Sun Feb 05, 2012 1:40 am
Any VHT type exhaust header paint will do, halfords sell it.
Rub them down and paint them, would be easier with them off but you need to remove the engine to get it off.
Also, they rot from the inside out too so it's a bit of a loosing battle.
phil x
Bike owned: 2 x 650 Transalp's, '90 nc30
Post by phil x » Sun Feb 05, 2012 8:13 am
Vht your only budget option really, but is porus to let the heat out & will rust in time. Regular recoating does help.
Phil
Vfr400/tbird
Post by Vfr400/tbird » Sun Feb 05, 2012 1:19 pm
Thanks ill have a look, the other product i was looking at was a rust convertor from toolstation that is black in colour its a little cheaper than the VHT stuff but im unsure of the heat rating.
The rust convertor has one benefit over the VHT, if it works, as its brush paintable!
http://www.toolstation.com/shop/Paintin ... 152/p43408
Heres a link if your intrested!
ludacris
Bike owned: NC35
Post by ludacris » Mon Feb 06, 2012 2:51 am
well I know that heat resistant anti-rust primer exists so that may be something to look into also
paul.s
Post by paul.s » Mon Feb 06, 2012 12:14 pm
the only way you will stop the rust coming back is to chop it off and replace the rusted part. anti rust treatments only work on the first micron or so of rust any rust underneath carries on the advice to just keep redoing it is your best bet .a good wire brush up and brush some bbq paint on and re do it as req
