nc21 carb rubbers
Posted: Mon Jan 09, 2012 11:29 pm
by john21z
anyone know where i can get new carb rubbers for a nc21zh from .im contenplating striping my carbs down
because im getting a strong smell ov fuel when the bikes running.i think one ov the float bowls needs ajusting and i reckon when i take the carbs of
the rubbers will probly fall to bits. just my luck.
so if anyone has any info on this subject or knows where to get some
new carb rubbers from. please let me know
Re: nc21 carb rubbers
Posted: Tue Jan 10, 2012 3:44 am
by Cammo
You can use nc30 carb rubbers, no problems at all.
Genuine parts can be had from the usual sources or there are cheaper pattern sets on ebay.
Posted: Tue Jan 10, 2012 10:18 am
Cammo wrote:You can use nc30 carb rubbers, no problems at all.
Erm.
NC21 has 30mm carbs.
NC24 /30/35 has 32mm carbs.
The actual carb body is the same on all carbs, but the later models are bored out more.
This would present a problem trying to use the NC21 rubbers with later carbs as the inlet is too small
I don't think the reverse is true but you dont' have much choice as the NC21 rubber is discontinued and unavailable.
If you phone David Silvers they'll be able to get the parts without the part number, if you want to order online from either vendor just put the following part number in.
www.lings.com -> Click Original Honda Part
www.davidsilverspares.co.uk -> Click search by part number
16211ML0000 - NC21 - No longer avilable.
16211ML0720 - NC24 carb rubber.. around 6gbp I believe (and avilable)
NC30 uses the same carb rubbers as the NC24.
