NC30/35 Titanium - Wheel, Hub & Yoke Nuts
All are grade 5 Titanium, plain finish (ie no anodising or polishing, just a plain machined finish)
NC30 ONLY - 41mm Yoke Nut - £19 + £2.99 P&P
36mm Wheel Nut - £25 + £2.99 P&P
46mm Hub Nut (Reusable) - £29 + £2.99
All 3 bought together as a discounted set = £60 + £2.99
these will be available in 5 weeks time, i hope there is as much interest as before but this time this is a GO'er
EDIT:
the hub nut with the holes drilled and split/R pin may cause you problems on a paddock stand, i think you can stake the nut tab in, but then it isnt reusuable, so ideally for Abba stand users or if you happy to remove the split/R pin each.
the holes i think will be 3mm Dia and will require drilling the hub and posibly the wheel spindle,
International shipping is £3.99, or £7.99 for signed-for.
I keep proof of posting and I won't accept any responsibilty for stuff going missing in the post if it's not sent signed-for.
EDIT:
Re: NC30/35 Titanium - Wheel, Hub & Yoke Nuts
Porndoguk - 1x Hub Nut
JUST TO ADD
Delboy
Porndog x1 hub nut
Vfrderek x1 hu bnut
Vfrderek x1 hu bnut
lizard821000
if you want somin done, ask ricky, simple.
Porndog x1 hub nut
Vfrderek x1 hub nut
lizard821000 x1 hub nut
Porndog x1 hub nut
Vfrderek x1 hub nut
lukemillar
Would you happen to know the weight savings for each part over OE?
Luke
Luke
they havent been made yet.
marcus57
Any chance of a 35 top nut?
amaechizzle
- Bike owned: NC35
If there is I would be down for all three!
