Hi-beam works but lo-beam doesnt...
Posted: Sun Sep 11, 2011 3:39 pm
by xivlia
okay, so i managed to fix my electrical systems on the bike. it was just a loose connection, but my low beam wont work. i went an checked all the connections and they seem to be fine...could it be the switch ? maybe there is a loose connection in the switch? other than that. it all seems to work fine..
cheers.
Ersan
Re: Hi-beam works but lo-beam doesnt...
Posted: Sun Sep 11, 2011 4:24 pm
A classic case of using the wrong light bulbs and the low beam in the switchgear dying is my guess.
You might be able to clean it up inside, but if you are ont running std lamps, you need to do a relay mod.. details are on the forum!
Posted: Sun Sep 11, 2011 4:39 pm
by xivlia
hmm okay. i checked the bulbs, i thought it was a single fillament bulbs thats why it wasnt working but thats not the case.. okay il look at the forums for relay mod, but how can i check if its a standard bulb or not?
Posted: Sun Sep 11, 2011 6:30 pm
by vfrman
It is the wattage. J-spec bulbs are 60/35 and UK are 60/55s The stock wiring cannot handle the 55 watt low beam.
Posted: Sun Sep 11, 2011 8:44 pm
by xivlia
hmm okay, i checked my bulbs and yes they are both 60/55w, i was reading the relay mod guide. and im a bit confused to wether i need a new relay to tap into the low beam wiring or to use the existing high beam realy to opeare both of them...so i need a nother relay of the same kind or not?
Posted: Mon Sep 12, 2011 12:31 am
by Cammo
You need to add another relay.
Any 12v 30 amp automotive relay will do, like this:
http://www.narva.com.au/products/browse/normal-open-4-5
Posted: Mon Sep 12, 2011 12:43 am
by xivlia
ahh okay, could i just but a nother high-beam relay off ebay? its cheap there.
Posted: Mon Sep 12, 2011 11:42 am
xivlia wrote:ahh okay, could i just but a nother high-beam relay off ebay? its cheap there.
There cheap in maplins. maybe 1gbp.
you could use another one of the same relay the hi-beam type.
You still need to repair your switch though... either clean out the melted bits inside or replace it.
Posted: Mon Sep 12, 2011 4:35 pm
by xivlia
ahh okay, il clean the switch and tap in a relay!
thanks.
