Page 1 of 2
nc29 - 39 tooth rear, is that all there is?
Posted: Thu Feb 24, 2011 7:28 pm
by amorti
As it says in the title really, chaps and chapesses.
I only seem to be able to find 39 tooth rear sprockets for the nc 29. I am putting nc29 wheels on my CB-1, which usually comes with a 41 tooth rear sprocket. It shouldn't make much odds because a 160/60-17 tyre is "shorter" than a 140/70-17 so in the end it'll about balance out, but it still surprised me that you don't seem to be able to get any other sizes?
Re: nc29 - 39 tooth rear, is that all there is?
Posted: Thu Feb 24, 2011 7:39 pm
by chrisja2
You running a 525 or 520 chain Aaron?
Posted: Thu Feb 24, 2011 7:43 pm
by Wozza
Yes.
You have to options:
1) Convert to 520.
2) Buy a sprocket for a CBR900 96-99 (same as some 600s) - requires modification. The mounting holes on the NC29 sprocket are 10.5mm dia.; 12.5mm on the 900 sprocket. Parus had some studs made up with a 12.5mm central section between each thread; I made some spacers to fit the standard sprocket studs. I suppose another option might be to drill and tap the threads in the sprocket carrier so you can use 12.5mm studs.
Note these diagrams:
http://www.jtsprockets.com/52.0.html?&L ... uid=324&p=
http://www.jtsprockets.com/52.0.html?&L ... id=4875&p=
If you want a 42T CBR900 rear for the above I've got one I no longer need.
Posted: Thu Feb 24, 2011 7:44 pm
by amorti
chrisja2 wrote:You running a 525 or 520 chain Aaron?
I think 525 is standard on both nc27 and nc29? Anyway, that one, as I am more interested in longevity than lightness.
Posted: Thu Feb 24, 2011 7:53 pm
by veefer400
Im sure Renthal do different size alloy sprockets for a '29?
Posted: Thu Feb 24, 2011 9:00 pm
by amorti
Wozza wrote:Yes.
1) Convert to 520.
A big THANK YOU!
Now there's an interesting idea. I have a spare CBR900 rear wheel in the garage, I could test the sprocket carrier on the nc29 wheel, never know, it might be as easy as that!
Posted: Thu Feb 24, 2011 9:03 pm
by amorti
veefer400 wrote:Im sure Renthal do different size alloy sprockets for a '29?
Not sure either way - but I probably should have specified - I have less than zero interest in alloy sprockets.
Posted: Thu Feb 24, 2011 9:09 pm
by Wozza
I'm 99.9% sure they don't, not in 525. Strange I know.
amorti wrote:Now there's an interesting idea. I have a spare CBR900 rear wheel in the garage, I could test the sprocket carrier on the nc29 wheel, never know, it might be as easy as that!
Good idea! Let us know the result.
Posted: Thu Feb 24, 2011 9:20 pm
by amorti
amorti wrote:Wozza wrote:Yes.
1) Convert to 520.
A big THANK YOU!
What's even better, is that using that JT website I have figured out that if I can get that rear sprocket on, which I am sure it's possible, then the humble '04-'08 CBF500 uses the same front and rear sprockets as I would be using, so I could still pick up kits relatively cheaply rather than buying the component parts. Brilliant!
Posted: Thu Feb 24, 2011 9:38 pm
by hallsie
I got mine from GF and put a 15 40T combination on with a 520 pitch chain , I know Graeme had other rears as well including a 42T if I remember correctly as it's in one of my older posts .
