carbs ultrasonic cleaning, before and after
Not that long ago, I bought a set of NC35 carburettors for my NC30. Got them for a good price, they came with the airbox and the grim
So after seeing a couple of posts here about these ultrasonic cleaning machine, I decided to take the plunge and buy one.
Didn't want to spend big money on such machine, so I got one for £26.95 off fleebay (290513180040). I had to fetch it myself from the courier company....
Was it the right size?
yes and no, you can't submerge a full carb so you need to turn it round and do several cycles of cleaning
Is it efficient?
I'll give 8.5/10
The crap that came out of one single carb body... see first picture below
I used some "Gunk" Engine de-greaser to finish them up.
Would I recommend such cleaning machine?
If you're going to clean a few carbs, then spend the money and buy a bigger machine, if it's just a one off(ish) job, then that small one is more than fine.
There is no way you can clean them just by using some de-greaser alone.
Pictures are worth a thousand words, so a few selected ones:
And for a super mega large picture
http://www.thefroginator.co.uk/fm-pix/a ... AG0278.jpg
Here's a video
As you can see from the color of the liquid... that carb was rather dirty
Is it efficient?
I'll give 8.5/10
Here's a video
- geebus
- Bike owned: 1990 VFR400 NC30 + SV650s
Re: carbs ultrasonic cleaning, before and after
that is very impressive. might have to order me one!
- ibby4585
- Bike owned: SP's
Nice ! What solution did you use?
Kris
Kris
I used this one from fleebay 290499008890
ibby4585 wrote:Nice ! What solution did you use?
Kris
forgot to add something, the pictures really don't do justice.
I don't have good lighting to take some nice pictures in my flat, but when you hold a cleaned piece next to the dirty one... it's night and day
- micpec
There is also Tickopur (solution in R33 and R77), but not sure if these can be bought at your location....well, it should be. Btw, nice little write up with the pictures how it is done with this ultrasonic cleaner
- uber pikey
Nice, I can't believe I just waisted 40 seconds of my life watching that video!
you could have had a before and after
I saw it so I took it!
I bought a slightly more expensive one from ebay £189 with temp control dimensions 300X100X100 and its been fantastic.Bought similar solution and some seaclean solution from maplins. Cleaned 2 set of nc30 carbs, 1 set of rvf carbs and a rather nasty set of superdream 125 carbs which were in a very bad way. Started cleaning alloy footrests and all sorts now. Well worth the money.
