what are NC30 carbs worth?
porndoguk
Post by porndoguk » Mon Aug 09, 2010 12:55 am
i got a set of carbs that are in good nick, im trying to get some cash together to fund my fork upgrade mainly as this month has been horendous in the "financial dept"!
there from a 1989 NC30 and could do with a little clean,
they have 110 jets all round, 4 and 5 holed emulsion tubes, and ive also chucked in so 0.5mm washers, theses where taken out of my bike litterally days after i bought it so i could tune another set and then throw them in,
the hole in the slides are the standard 2mm dia ish hole un altered, so everything is standard and the extra washers on the needles can be added or removed if required,
i also have the mounting bracket, BUT NO inlet rubbers, choke cable or idle cable,
the left hand fuel inlet is split and cracked but i can put a 7mm fuel line back on, but i guess this part can be replaced,
what will they be worth i spent £60ish for the other set of carbs i had but need to recoup as much as posible?
thanks Rick
micpec
Re: what are NC30 carbs worth?
Post by micpec » Mon Aug 09, 2010 7:13 pm
I don't know what this is worth, but have word with fellow member Drunkn Munky as he is on the outlook for some NC30 carbs.
Post by Drunkn Munky » Mon Aug 09, 2010 7:21 pm
Im already sorted cheers :grin:
As for value, there was a set of NC35 carbs on ebay, short stacks, filters, airboxes and it sold for £50 delivered. Im guessing you wouldnt get as much for the 30 carbs.
micpec
Post by micpec » Mon Aug 09, 2010 7:45 pm
Okidokie! :wink:
