damm overfueling
V4 Nut
Bike owned: VFR NC30 (1989)
damm overfueling
Post by V4 Nut » Mon May 03, 2010 11:20 am
hey,
looking for some advice as you can tell from the title my nc30 is overfueling so i was thinking about taking the air filter box off to settle the overfuling?? dose this stand any chance of working or am i pissing in the wind? :P
superlite
Bike owned: TLS, LB80 x 2
Re: damm overfueling
Post by superlite » Mon May 03, 2010 11:34 am
V4 Nut wrote: dose this stand any chance of working or am i pissing in the wind? :P
Pissing into a gale force wind :grin: That'll make your problem a lot worse.
Why do you say it's over fuelling? What carb settings are you running?
V4 Nut
Post by V4 Nut » Mon May 03, 2010 11:36 am
at the moment standard setting's but all of the sudden i have had a few little drips from the overflow pipe on the bike and i have this exhaust popping when i let off the rev's.... so first thought was overfueling :grin:
superlite
Post by superlite » Tue May 04, 2010 12:14 pm
V4 Nut wrote:at the moment standard setting's but all of the sudden i have had a few little drips from the overflow pipe
The carb overflow? If so, you probably need to check their condition and settings (particularly float heights).
Old Painless
Post by Old Painless » Thu May 06, 2010 8:47 am
If the overflow is running you probably have worn float valves.
V4 Nut
Post by V4 Nut » Mon May 10, 2010 1:00 pm
ok cheers guys i'll have a look, :grin:
