Steering Wobble
ONDA SF
Bike owned: Honda CB 400 super four
Steering Wobble
Post by ONDA SF » Mon Jun 15, 2009 9:22 pm
Riding home today and my arms started to ache, so took both hands off the handle bars, to shake them out a bit, the front started to wobble, like it had an unballanced wheel or something. (doing about 40mph)
I cant feel it when holding on to the bars though. has any one else noticed this on their superfour is it normal ?
frank
Re: Steering Wobble
Post by frank » Tue Jun 16, 2009 7:14 pm
Did you hit the front wheel off anything recently ie a kerb, pothole etc? It could be a slightly warped front wheel from an impact like this. That would cause a wobble, especially at speed. Try getting the wheel balanced and see if that cures the problem.
Frank.
ONDA SF
Re: Steering Wobble
Post by ONDA SF » Tue Jun 16, 2009 7:46 pm
frank wrote:Did you hit the front wheel off anything recently ie a kerb, pothole etc? It could be a slightly warped front wheel from an impact like this. That would cause a wobble, especially at speed. Try getting the wheel balanced and see if that cures the problem.
Frank.
Not hit anything, think I will do like you suggest and get the wheel ballanced
wullvfr
Bike owned: zx9r c1
Re: Steering Wobble
Post by wullvfr » Wed Jun 17, 2009 9:53 am
i would check the front wheel for all possible causes,i would check the wheel bearings and to see if the wheel is straight.
wull
karltheboy
Re: Steering Wobble
Post by karltheboy » Fri Jun 26, 2009 8:14 am
my bikes does it too if i let go it tries to do a tank slapper and can be quite scary to grab the bars again
ONDA SF
Re: Steering Wobble
Post by ONDA SF » Sun Jun 28, 2009 7:44 pm
wullvfr wrote:i would check the front wheel for all possible causes,i would check the wheel bearings and to see if the wheel is straight.
wull
Managed to sort the problem, it was really technicial though and if any one has the same problem here is the answer.............
I put some air in the front tyre :whistle:
What a plum I am :oops:
Thanks for your help though
earthbound14
Re: Steering Wobble
Post by earthbound14 » Thu Jul 30, 2009 5:55 am
Just a quick add on, a wobble can also be caused by a unbalanced front suspension. If you get one seal done (let's say if only one has blown) rather than both (cause you're cheap like me) then you may find your bike has a bit of a wobble.
Ensie 27
Re: Steering Wobble
Post by Ensie 27 » Wed Aug 05, 2009 3:26 am
Also caused by worn head race bearings and/or incorrect fitting or worn rear tyre and/or shock.
