nc24 rear shock mount
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Post by dunkenb » Fri Jun 05, 2009 8:09 pm
is the rear shock on an nc24 off set like on the nc30?
cheers
dunk
Re: nc24 rear shock mount
Post by Neosophist » Mon Jun 08, 2009 9:09 pm
Offset? you mean the top and bottom?
Hagon shock
Standard Shock
dunkenb
Regular Member
Post by dunkenb » Tue Jun 09, 2009 6:05 pm
i meant as in is the shock on the 24 mounted in the centre of the swing arm or toward one side like the nc30?
Post by Neosophist » Thu Jun 18, 2009 12:37 pm
Oh yeah the shocks in the middle, not offset like the NC30/NSR250R
dunkenb
Regular Member
Post by dunkenb » Sun Jun 21, 2009 2:04 pm
cheers, i want to mount the one i have to my nsr 250 .
i have an nc30 hub i'm fitting in the nc24 swing arm, will i need a spacer or will the nc30 wheel fit without one!
cheers
Post by Neosophist » Sun Jun 21, 2009 10:28 pm
tbh i'm not sure.
Are you trying to put the whole hub in the swingarm or are you just going to put the wheel shaft thru the 24 hub?
dunkenb
Regular Member
Post by dunkenb » Mon Jun 22, 2009 4:47 pm
i was gonna use the nc30 stub axle in the 24 hub in the 24 swing arm, with a nc30 wheel. And using the 24 sp rocket as it has cush drive.
dunkenb
Regular Member
Post by dunkenb » Fri Jun 26, 2009 6:50 pm
well the nc24 cush drive/sprocket carrier doesn't fit on the nc30 stub axle ( too small) and i had to get the nc30 stub axle to get it to fit on the nc24 roller bearing but other than that it's going well. :grin:
Post by Neosophist » Sun Jun 28, 2009 11:36 pm
oh cool! full write up / pics when its gdone please :)
dunkenb
Regular Member
Post by dunkenb » Mon Jun 29, 2009 12:11 pm
well i've had the nc30 axle machined so it now fits the 24 hub, was about 2mm out. only prob now is that machining that much off has removed the hardend bearing surface for the roller bearing, so gotta get it rehardend!!!!
more to come.
