Nc30 - SV650 clipons
Re: Nc30 - SV650 clipons
Trying this aswell over the weekend or whenever I get some spare time and the parts arrive. Will post some pics of the install and any problems I run into
Finished fitting mine now on my nc30 and all seems good. The clearances on the front fairing stay are a little tight and I had to alter the angle of the killswitch to stop it catching. The switchgear on the left hand bar I had to remove the little holder bit and then put duct tape around the bar so it stayed in place when everything was back in place. All seems good other than that. The bars make it a loooot more comfortable while on the back, really takes the strain off your lower back. Would recommend this upgrade for anyone considering it, very easy to revert back to stock.
Cool, pleased you got them on.
Good to hear - and any particular model/year of sv650? Assume the s model...
I took a chance and went with the older 2001 model from ebay, not sure if other years will fit though.
I think the ones I used were 03-08 version with the locating pin rather than the bolt hole of the earlier models.
Absolutely amazing mod on the 29 I only need to stop for fuel. I had to stop every 30 miles before.
Used the Mk 2 clipons, had to make brake res bracket and move the throttle so cables are facing downwards.
