ohh i want this .....
RonniB
Re: ohh i want this .....
Post by RonniB » Sat Aug 13, 2011 12:54 pm
Its not that I don't like the look of it, but it's very much form over function when it actually does the opposite of the real deal (slows down wheel changes instead of speeding them up). But the look is sweet. What I tried to say (a bit clumsy) was that a real QD axle is quite easy to have made, I guess it would cost about £70-100 to have it machined.
Tony, if you like a sketch, I'll come up with something, but Royster said quite good. You make an internally treaded bush, which is held in the lefthand side forkbottom by the pinch bolts, it most be shaped like tophat, so that it doesn't pull through when the axle is torqued up. The axle is just a fancy bolt, with the same tread as the bush and a small groove machined right under the head, so that you can secure the socket guide with circlip.
Ronni
royster81
Post by royster81 » Sat Aug 13, 2011 3:57 pm
Couple that with some captive spacers and it would make a fancy front end
Post by Drunkn Munky » Sat Aug 13, 2011 6:09 pm
Ok lets do this properly then, ronni if you could sketch out some ideas for the axle so it works as it should with the socket guides that would be great. I'll email drew again for the measurements of the guides if that wil help
royster81
Post by royster81 » Sat Aug 13, 2011 6:17 pm
I'll just go for the jap look-e-likey thanks.
royster81
Post by royster81 » Sat Aug 13, 2011 8:50 pm
http://page14.auctions.yahoo.co.jp/jp/a ... s238818583
oh oh oh oh this this this............
porndoguk
Post by porndoguk » Mon Aug 15, 2011 6:29 am
viper61
Post by viper61 » Mon Aug 15, 2011 4:52 pm
Ok. i'm special...
What are they? Like a captive spacer to enable quick wheel releases... or sumfink? :?:
RonniB
Post by RonniB » Mon Aug 15, 2011 9:05 pm
they are there to guide the socket onto the axle/axle bolt, when doing wheelchanges..
DM, I will just have to dig out an axle (NC30, is it the same as a NC35??) and do some measurements, then I post a sketch. Meanwhile, feast your eyes on this http://www.s1000rrforum.com/forum/bmw-s ... ation.html it's a BMW, but ignore that, the principle is the same and very simply engineered. I would make a loose socket guide in alloy instead to save some weight (and then you can anoidise it whatever colour you like.)
Ronni
SouthSide
Post by SouthSide » Wed Aug 17, 2011 11:07 am
RonniB wrote:they are there to guide the socket onto the axle/axle bolt, when doing wheelchanges..
Ronni
Does anyone know what the black material is that's used in the last photo to create that cone?
RonniB
Post by RonniB » Wed Aug 17, 2011 7:16 pm
engineering plastic; delrin, long-strand nylon or similar.
