Nc23 max fuel pump pressure
just4kicks
Post by just4kicks » Mon Feb 19, 2018 6:26 am
Hi all, as the heading states, what is the max pressure the fuel pump can be for a Nc23? I can get 1 new locally which is labeled for a cbr600 carb model 1987; 1988 etc but the rating is 80LPH and I've seen on Amazon that the Nc23 pump is 55-60 LPH. Will the 80 pump be too strong for the Nc23?
CB1pod70
Re: Nc23 max fuel pump pressure
Post by CB1pod70 » Tue Feb 20, 2018 10:39 am
The CBR600 unit should be fine as the same fuel pump was used on a whole range of bikes from all sorts of manufacturers. the only thing to check is the diameter of the inlet & outlet stubs as they come in 6, 8 & 10mm. I use 10mm hose on the race bike but typically 8mm on the road bikes.
