Idling high
86gtv
One Hit Wonder
Idling high
Post by 86gtv » Fri Nov 25, 2011 12:20 am
Hi guys iv got a nc30 vfr 400 and its idling at around 4k and the adjustment screw doesn't work! Is there any other way to lower it??
makz2008
Bike owned: NC30, NC35
Re: Idling high
Post by makz2008 » Fri Nov 25, 2011 12:39 am
are you sure the choke isnt on?
Hadies
Re: Idling high
Post by Hadies » Fri Nov 25, 2011 1:08 am
+ 1. Choke might also be stuck on at the carb end. I would also get a new idle screw.
Re: Idling high
Post by Neosophist » Fri Nov 25, 2011 10:33 am
Is the idle screw moving?
Choke stuck on?
Air leak? How's it run
Gadget
Re: Idling high
Post by Gadget » Fri Nov 25, 2011 6:16 pm
If you, or someone else has turned the idle adjuster knob/cable too far anti-cockwise, the idle adjuster cable will become detached from the throttle body.
Also.....Choke cables can become frayed at either the carb end or the choke lever end which will cause the cable to jam.
