Hello to all.
I have an NC30 and in need of a left hand switchgear, but, I was wondering if anyone knew whether the switchgear was interchangeable with other Honda's or around this period, I'm pretty sure that the NS400 right hand switchgear was interchangeable with the first VFR400 - any thoughts?
Honda Switchgear - interchangeability?
Re: Honda Switchgear - interchangeability?
I don't know of any others that are simple plug and play.
I have some rvf L/H switchgear waiting to go on my nc30, just need to screw around with some of the wiring. No big job if you have the wiring diagrams in front of you.
If you do manage to find something from the same era as the nc30 that fits it will just as likely be as poorly made as the stock nc30 part (there's a good reason so many play up!)... a newer upgrade is the way forward.
- Bike owned: nc 30 dt50
I found one off a cbr125 looks on the switch the same ,apart from the dip switch but the wiring looks different
- Bike owned: RVF400 - ZX636
I have a good set of switchgear available for the '30.
- iDemonix
- Bike owned: '92 NC30
With a wiring diagram I imagine there's 1 or 2 you could wire up.
