VFR400 OIL LIGHT and braded lines
Re: VFR400 OIL LIGHT and braded lines
Post by Neosophist » Mon Jul 11, 2011 12:00 pm
That oil light is very worrying.
Especially since it didn't come on before.
It sounds as though your getting low oil pressure at idle. (do not run the bike until you can confirm this isn't happening as you'll get engine damage)
Maybe oils getting too thin!?
10/40 is the correct grade synth or semi synth (semi synth is prefectly ok) if there the same grade they should behave the same.
Is the oilstraner clear? (its in the sump) and nothing blocked?
Perhaps draining the oil has moved some crap in the engine?
johnnie5
Post by johnnie5 » Sat Jul 16, 2011 1:02 am
i would be sus of the oil filter
GIXERMARK0
Post by GIXERMARK0 » Mon Jul 18, 2011 7:33 am
hi
did a test started bike no oil light on as it warmed up oil light came on as the temp rose the revs needed to keep the ligth off rose from 1500 rmp to 3000rpm
you could hold the revs at 2000rpmand after a wile the light came on so increse the revs to 2500rpm all ok but after a time oil light came on
it didnt do it when the oil was first put in
off to find a pressure switch new oil and filter
any other idears
thanks for the replys
