What is it about nc30's starting
playboy
Post by playboy » Tue Jul 12, 2011 12:18 pm
Everytime i start the nc30 up from cold with the choke on it starts first time, runs at about 5,000rpm sweets as a nut then you'll take the choke of and it'll die, you then can't start it for some reason? other times i'll leave it for 6-10 mins on choke then it'll be fine?(which is stupid when the neighbours moan) is this bike that finincky on start(never had this with the cbr400) is there a way or some handy tips to help?
when running its awsome and runs sweet its just the first time you start it??????
cheers
Re: What is it about nc30's starting
Post by Neosophist » Tue Jul 12, 2011 1:41 pm
You really shouldn't need 5 - 6 mintutes of choke!! 30 seconds should be more than enough, especially in the summer... perhaps the carbs arn't setup correctly which is why its requiring so much choke...
dave6970
Bike owned: SP-1, NC30
Post by dave6970 » Tue Jul 12, 2011 5:19 pm
I always start mine on the choke so it idles about 2000rpm , so as not to race a cold engine, and lower the choke to off as soon as it will run with out it on, which isnt long at all.
Hadies
Post by Hadies » Tue Jul 12, 2011 5:22 pm
I always start mine full choke, no throttle and roll it off slowly shortly after that until it can idle on it's own without choke.
Julesholling
Bike owned: Honda VFR400 NC30
Post by Julesholling » Wed Jul 13, 2011 9:56 am
sounds like the carbs need a tune up.
Mine starts on a bit of choke , leave for a few mins and push the choke all the way in. Doesn't take 5 mins idelling at 5000rpm though!
Post by Neosophist » Wed Jul 13, 2011 11:24 am
dave6970 wrote:I always start mine on the choke so it idles about 2000rpm , so as not to race a cold engine, and lower the choke to off as soon as it will run with out it on, which isnt long at all.
Racing a cold engine wont' happen on choke.. this is a common misconception.
The 4-5000rpm you get on choke give a good high oil pressure when the oil is cold and allows it to reach the top-end.
Never run an engien thats not underload (in gear) over 10,000rpm though, the chance of something breaking goes up exponentially after 10k.
Once the bikes started the procedure should be to pull in the choke until the engine is around 2-3000 rpm and loose it alltogether when it will idle without choke.
As per my original post.. carbs / engine service (valve clearnances) and air-filter inspection. are due.
