nc30 fuel leak
K18NEO
One Hit Wonder
nc30 fuel leak
Post by K18NEO » Sun Oct 10, 2010 9:27 pm
I been out on my VFR400 today, and it developed a fuel leak. After stripping fairing, tank and air filter off... i think ive found where it is located.
Has anyone experienced any fuel leaks? It appears its from a connector pipe inbetween the 2 carburettor but i wondered if there was any commen places? i can provide pictures too...
Re: nc30 fuel leak
Post by Neosophist » Mon Oct 11, 2010 10:30 am
There are O-rings on the ends of these pipes.. bit of a ballache to change but not too bad.
I recentley changed all the O-rings on a leaky set of ZXR carbs, £20 for 12 o rings but it stopped the leak :-)
I dont' see it very often but it does happen.
Usually if the bikes been run with a fuel additive that isn't totally rubber safe.. especially if its sat with fuel in it, i've seen two sets of carbs, one was virtually leaking fuel everywhere due to perished o-rings and float bowl gaskets, the fuel pipes were also very brittle and porus.
The only difference was one had had some fuel additives put in it regularly, this I conclude ate the rubber away.
Of course they will go over-time anyway.. but the other bike was immaculate in comparission, both had similar miles too.
